Configuring trusted proxy CA credentials
To configure trusted proxy CA credentials (certificate and private key), edit the Certificate Authority frame:
From this window, you can:
• either import a Certificate existing in your IT environment, by clicking the Import button:
• you can choose to import a CA Certificate (Signed Certificate Signing Request):
• or a CA Certificate + a Private Key:
If the Proxy CA Private key you import is encrypted with a passphrase, this passphrase must also be provided to the Appliances belonging to SSL proxy enabled Sites.
• or generate a Certificate after defining the following parameters (parameters in bold characters are mandatory, other parameters are optional):
• Common name (CN),
• Passphrase (has to be entered twice, if used): use it if you want the Proxy CA Private key to be encrypted with a passphrase, to raise the security level of SSL Optimization.
• Expiration date
• Organizational Unit (OU)
• Organization (O)
• Country (C)
• State (ST)
• Locality (L)
• Click the Generate self-signed CA button to generate the certificate which is immediately displayed:
or
• Click the Generate CA Request (CSR) button to generate a certificate request which needs to be sent and signed by a Certification Authority. The system automatically asks you to save the file. Hit OK to confirm.
The proxy CA certificates must be in your workstation trust-store.
